Agreed, but I read his main point, and my point in the previous post, to mean that one you had established comms, subsequent calls for “requests” should ask the request, not just say “request.” The latter would require an additional round of comms. For instance:
Atlanta Center Cirrus 1KM, Request
Cirrus 1KM Say Request
Cirrus 1KM Request descent to 10,000
Cirrus 1KM, descend and maintain 10,000 ten thousand feet.
Vs.
Atlanta Center Cirrus 1KM requests descent to 10,000
Cirrus 1KM Descend and maintain one zero, ten thousand
AC could also respond with silence, “1KM stand by,” or “1KM, Maintain 12,000.”
In all instances the entire transaction is more concise. Quite frankly, he also suggests leaving off the “Atlanta Center.”
My practice is to only use the “request” call up if the request is other than direct flight clearances. For example, If I may need WX help or a reroute, then I use request. I use it to signify a lower priority request. However, in all situations I try to tailor my phraseology to the congestion on the freq.
Marty,
I haven’t read the article. Generally, I agree. My practice is as follows:
If I’m VFR making first contact, I say “XYZ Approach, Cirrus November One Mike Romeo, VFR Request” (or, if they’re NOT busy, I make the request).
The point of the “VFR” in my initial callup is to save the controller the mental exercise (sometimes a scramble) of looking over the callsigns of aircraft that might be on his handoff list.
I almost never start my transmission with the name of the faciility except on my initial call to that facility. Doing so at other times is another case where the controller’s brain is put into the “Here’s a new aircraft for me to handle” mode, albeit fleetingly. For me, the exception to this rule embodied in…
1MR requesting ten thousand
(No response)
… wait a while…
(No response)
… wait a while…
1MR, request
(No response)
… wait a while…
Philly Approach, November 1MR, how do you read?
Calling Philly Approach, say again, I was on the land line… (or similar)
Relatively speaking, we’re all counting angels on a pinhead here… the main point is for pilots and controllers to communicate clearly, and be sensitive to bandwidth when things are busy.
