Still have some SR20 Interior touch-up paint available. After a long process I finally obtained the exact color match for the interior paint on the early SR20s. This is a gray surface coating used on the first 75 or so aircraft. At some point in the production Cirrus went to an imbedded color in the plastic. Unfortunately, the early paint scratches easily and shows the white plastic base. The paint is not available from Cirrus and had to be obtained, by special order, directly from the Sherman Williams plant. It was only available in one gallon quantities, much more then I need. If anyone else needs this paint I will put in pint containers and ship it to you. The charge, to cover my costs, is $15.00 plus shipping. Contact me for further information.
Stuart Herbst N176CD
