My current plane has an Apollo SL60. This radio, as well as other Apollo radios, allow you to monitor two frequencies with one being the primary frequency. I use it all the time. Is this feature found on the Garmins?
Thanks
David Raab #264
One of the original April 2001 Cirrus Fly IN attendees. (arrived in a Cheetah)
Yes.
(I’m assuming you mean,eg, pressing the COM2 button to listen to that freq, while listening/transmitting on COM1.Even the ancient training Cessnas I used had that function. Do you mean something more than that?)
The cool thing about the Garmin intercom is that it allows you to split com 1/2 so that the pilot can transmit/listen to one freq while the copilot traismits/listens to another. This is a function of the intercom. Of course, it will also allow you to monitor both freqs. The manual for the intercom is downloadable at the garmin website.
Thanks
David Raab #264
Yes.
Jim,
I think the new Apollo radios have a feature where a single COM radio can be transmitting and receiving on the active freq while also monitoring (i.e. receiving) on the standby frequency. This is not a function of the audio panel (i.e. not COM1/COM2 switch like you mention) but rather a feature of the COM radio itself.
David,
The Garmins don’t do this. The COM portion of the Garmins is very much like just a regular flip/flop COM (with some extra features like being able to program the standy frequency from the GPS database, etc.) So the only way to listen to two frequencies at once is like Jim suggested, just using the audio panel to listen to the 2nd COM radio.
Steve,
Thanks, you got my question correct. The nice thing about the Apollo is that it cuts out the other frequency when the primary frequency is active. Never miss a call with this function. Hey Garmin…this would be a nice feature to add!
David
Sounds like a good feature – certainly handy for getting ATIS. The main difference from the tried-and-true “press the COM2 button” approach is the auto-squelch when there’s a transmission on the primary freq, right? That too would help for ATIS.
And, hey, if you had a second Com radio, you could monitor four frequencies total and really go crazy.
