HI all,
Is there any way to connect music(cd’s) into a headset during flight??(With auto cutoff when radio is transmitting/receiving)
According to the GMA340 POH, MUSIC1 wil serve that function.
There has been substantial discussion on this topic in the various forums - you can use the search function to find them (try searching for “music”, “cd player” or “jukebox”). But basically all you need
to do is plug a CD player (or even better, an MP3 player like the Archos Recorder) into the socket that is inside and at the back of the centre console (next to the 12V utility outlet), using a cable with a 3.5mm stereo plug at each end. The music will then come through the headsets (in stereo) but will be interrupted by the radio or intercom.
If you have an older Cirrus with the Telex-style headset power connectors, then you can even use one of those to power the Archos, since those outlets conveniently deliver 9V.
