Hello All,
My name is Dimitri and I’m a CFI out of Santa Barbara County. I hold nearly 500 hrs in a G3 SR22T and always had trouble with the low flap speeds of 119 knots for the first set. I recently started flying a 2022 G6 SR and found the flap speed extensions of 150 knots a game-changer. Does anyone know of any STC to extend the flap speeds on older model Cirrus aircraft?
While the lower Vfe for the earlier SR22s can be a challenge sometimes, it is very easy to accommodate. I had my G2 SR22 for 15 years and 5300 hours before I sold it, and taught many hours in the SRs, and it was rarely a problem - even for students or pilots that rented it.
It just takes planning and situational awareness. I fly, and teach, in aircraft with Vfe up to 200 Kts and I have a standard practice. I plan to be at approach flap speeds (50% in the SR) 8-10 nm from the FAF in all aircraft - whether it is a jet, turboprop, or piston. If VFR, then you can set a similar distance from the airport. I typically fly 2-4 different jets each week, and usually something else as well and by following this process it makes my flying much easier. Using this or a similar SOP pilots can maintain better SA and plan ahead.
One of the biggest issues I’ve seen over 20 years teaching in the SRs (45 yrs as a CFII) is lack of planning and understanding the aerodynamics of the aircraft. This is readily apparent if they transition from aircraft with more effective flaps such as a Cessna.
The key is that you can’t go down and slow down at the same time in a Cirrus. So, the trick is to maintain altitude or even climb a little bit, at low/no power, to get below the 119 knots, then extend the flaps.
I have often flown ILSs at 150-170 knots when requested by ATC (I am based at a busy class C airport), and at about 600 AGL - so very close to the runway - just level off and pull the power back, and it just takes a few seconds to slow to flap speed. But, if instead, you continue descending - even with little or no power - it will take forever to slow down.
This depends on the prop. The three blade composites will. The four blades even more so. But, agree with your sentiment completely on leveling off to slow.
