Update as of 2026-03-02T08:00:00Z
Effective 2026-03-01T08:00:00Z, Starlink introduced two new Aviation plans: Aviation 300MPH and Aviation 450MPH. The Roam, local/Global Priority Plans are now limited to < 100MPH usage.
Aviation service has additional regulatory requirements; certain aircraft and identity details are required to enable reliable service across regions.
If you are interested in switching to one of these plans, you must create a support ticket including the following items:
- An upload of your government-issued passport
- Aircraft tail number
- Aircraft type (SR20, SR22, SR22T)
Comparing Aviation 300MPH and Aviation 450MPH
| Details | Aviation 300MPH | Aviation 450MPH |
| Base Monthly Subscription | $250 USD | $1,000 USD |
| Included Data | 20GB per month | 20GB per month |
| Supported In-Motion Speeds | Up to 300 mph (482 km/h) | Up to 450 mph (724 km/h) |
| Overage Data (Opt-In) | $10 USD per GB | $50 USD per GB |
| Coverage | Coverage over land, territorial waters, and within 12 nautical miles of the coast | Same coverage as 300MPH, plus ocean coverage |
| Identity Verification | Required | Required |
Previous Starlink announcements:
Effective 2025-11-07T08:00:00Z, Starlink will be lowering the maximum supported operating ground speed for all Roam, Local Priority, and Global Priority plans from 550 mph (471 knots) to 450 mph (391 knots).
Update as of 2025-10-10T07:00:00Z..
On 2025-10-10T07:00:00Z at COPA Migration 2025 in Amelia Island Florida, Cirrus Aircraft announced an offical OEM Starlink Cabin “skylight” windows Mount and Power solution.
Its coming soon!
Expect to be able to order from your Cirrus Service Center by the end of November.
More info to come soon!
Here is a video on its design and ease of install and removal
Update as of 2025-09-15T07:00:00Z
No Longer Valid | Roam 50GB Plan
The Starlink Roam 50GB plan Works in motion upto 450mph/391 knots ground speed and provides coverage in territorial waters and inland waterways (up to 12 nautical miles from the coast) for 5 consecutive days and up to 60 days per year.
You can additionally add Ocean Mode on the Roam 50GB Plan and be charged a Per GB charge beyond the 12nm from the coast limit.
- Ocean Mode also provides higher network priority than Roam data. While it is intended for use on/over water, you can enable Ocean Mode while on land (billed-per-GB) and receive higher priority service compared to Roam data.
Find more about Starlink Roam Plans on the starlink FAQs
Starlink in Cirrus Background
Since the introduction of the Starlink Mini in July 2024, there has been a lot of excitement among the Cirrus/COPA community, along with GA in general. This was primarily for three reasons:
- Size
- Low power requirements and voltage flexibility
- Originally, a cheap $50/month service plan
However, the cheap service plans didn’t last long.
It went from $50/month to $250/month for speeds of 100-250 knots +/-.
This priced many out of the market.
For those in faster SR22T and SETP’s, the 250-knot speed limit really reduced usefulness.
For speeds greater than 250 knots, you needed a $2000/month aviation plan, which only a handful of users utilized.
Then new Local Priority plans came out on 2025-03-17T07:00:00Z at $65/month that worked at Cirrus and SETP speeds. There was a resurgance of Buzz around the Starlink Mini.
Later on Roam 50GB Plans @ $50/Month started working again at our speeds, and then expanded to 100GB of data.
This then changed again on 2026-03-01T08:00:00Z with the immediate implementation of Aviation 300MPH and 450MPH Plans. Roam, Local/Global Priority Plans were all immediately restricted to <100MPH again.
So for the Typical SR20/22 we now at back to the begining cost $250/month.
So what is needed to get started?
- 1 - Starlink Mini (obviously)
- 1 - Active StarLink Roam 50GB Service Plan
- 1 - Reliable power source (Cirrus center console cigarette jack will NOT work) - Update from Cirrus Can be purchased through your Cirrus Service Center
- 1 - Proper power cable
- 1 - Window mounting system (for clear view of satellites)
Reliable Power:
Starlink needs 60 watts, primarily for startup (20-30 watts continuous). It can accept 12-48 volts.
There are two paths when it comes to providing reliable power:
- Ship power
- Portable battery packs
Ship Power:
Specifically in the Cirrus, the 12-volt center console cigarette plug is NOT capable of providing enough power to the Starlink.
Many of the USB-C chargers in the wild are not capable of providing enough power as well.(some are)
The recommended method is: Ship power, Via the New Cirrus Service Bulletin: SB??? or for older G1/G2/G3 Airframes via a dedicated 28-volt TSO’d cigarette lighter receptacle
This needs to be installed by an A&P of your choice.
Installation cost will vary between $800-1500 approx.
The following is a parts list needed for this install, feel free to share with your A&P:
- Qty 1 - Circuit Breaker 5amp
- Qty 1 - 28-volt TSO’d Cigarette Lighter Receptacle
- Approx 20 ft - Shielded 18-2 wire (M27500-18TG2T14)
- Misc parts needed… connectors, wire ties, etc.
The circuit breaker can be used to disable/reset the circuit if needed.
However, a switch should be added if you feel you will enable/disable the Starlink in flight often for various reasons (keeping kids/spouse in line maybe
). Add the following if you like:
Battery Packs
Battery packs have risks! COPA caustions against the use of these. ![]()
There is also the inconvenience of charging and swapping out the battery packs.
Note: Battery packs should not be left in the airplane. Remove Battery Packs from plane when not in use.
There are two primary types of battery pack technology:
- Lithium Ion (Standard Battery Banks)
- Lithium iron phosphate battery (LiFePO4)
The LiFePO4 battery has the edge over lithium-ion in both cycle life (lasting 3-5x longer) and safety. Lithium-ion batteries can overheat and catch fire much more easily, while LiFePO4 is extremely fire-resistant and very unlikely to overheat.
When going with either type of battery pack, it’s important to purchase from a reputable manufacturer.
While the following are slightly larger, these are safer and more flexible.
These have been found to be reliable and recommended by the community:
Anker - LiFePO4 Recommended
EcoFlow - LiFePO4 Recommended
Jackery - LiFePO4 Recommended
If you want to go with something smaller and lightweight, with a shorter runtime, some have found the following Anker 737 Lithium Ion Pack to be good. Just understand the risks and we would recommend a Lipo Safe Bag.
You may also need to have multiple of these for longer journeys.
Power Cable:
Depending on what method of power you go with, that will determine what cable you will want to use.
For those going with ship power, or battery pack with a cigarette plug, you will want the following:
Cigarette Plug to Starlink 5.5x2.5 mm Barrel Connector
For those that will use a battery pack with a USB-C PD port, we recommend the following:
Starlink Mini USB C Cable, USB C to DC Power Cable
If a longer cable is needed, Use the following extention.
Window Mounting System
While there are are several options for window mounting your Starlink Mini.
If you have a SR22/20 G3 or newer, Cirrus Aircarft has a OEM approved and Cirrus Service Center Installed Window mounting Mount!
If you have an older generation of that aircraft, there are several other options, personal preferance will determin what is best for you.
The COPA Community has found that utilizing the baggage tiedown brackets, in some way, is the best method. This method takes safety, reliability, ease of install/removal, and space-saving into account.
Cirrus G5 and Newer DIY PVC “BradKit” options:
Cirrus G1/G2/G3 DIY PVC examples:
Join COPA and Look at this link for more info:
Alternatively: You can also utilize Window Suction cups if you prefer.![]()
Note: suction cups can fail, and have been known to cause damage to the window in some cases.
There are some more “profesional” Cirrus Speciffic Mounts as well:
Secure the Starlink Mini to the mount with the included Starlink Mini pole mount and thumbscrew, ensure the mount is secure to the tie-down brackets with Zipties (Reusable ones are nice!).
Setup:
We recomend that you do the following first at home on AC power.
- Setup/activate Starlink Mini for the first time at home/outside with a clear view of the sky utilizing the AC power adapter. Several reboots may be needed, and the first-time boot can take a little longer than you would think. Once updated, connection typically occurs within 2-3 minutes.
- Starlink WILL NOT work inside the hangar.
- Disable the Snow Melt feature of Starlink to Help reduce power draw, freezing temps could auto trigger that melt feature. You can access and adjust the Snow Melt settings in the Starlink app by navigating to Settings > Starlink > Snow Melt
Starlink setup is straightforward, there are tons of how-tos about that. Follow the instructions in the Starlink app.
Using Starlink in Flight:
Do not allow Starlink to be a distraction. You are PIC! Set phones on DND / set a focus mode / or turn off completely when necessary. Don’t be that person that ruins this for everyone!
Ensure your WiFi-Calling is enabled to be able to send/receive SMS and make phone calls via Starlink.
Once connected to Starlink, it is recomended to put phones/devices in airplane mode with WiFi on. This is to optimize battery life of the device and provided better connection quality.
Do not forget to turn airplane mode off after landing and Starlink shutdown to continue phone connection.
Aviation / Flying Starlink Tips and Tricks:
- Using Windy.com, Aviationweather.gov, and other weather planning tools is great for Weather Planing both on and off the ground.
- Utilze Wifi Calling to call ASOS/ATIS earlier and when convienant.
- Utilze Wifi Calling to call FBO on the phone vs ASRI Freqency.
- Ordering Doordash/Uber Eats for that Quick turn Fuel stop! Use Shedule order feature for your ETA.
- Check Uber/Lyft Rates and aviably enroute.
- Check in with the Family adn Friends on updated ETA.
- Use Focus Modes on your phone to set custom notifcaiton settings while flying
*Consider setting your device to “Low data mode” for the Starlink WiFi. Some users have reported iCloud and other background syncing causing an excessive amount of data to be utilized on Starlink.
