I learned some things about the SR22’s avionics that I thought other owners might find interesting. A lot of this is small detail that might be fairly dull to non-gearheads. Also, some of this information was in previous posts. I welcome corrections to the many details below.
There is no way to download a flight plan or waypoints or anything else from a laptop PC to the GNS 430’s. This is unlike Garmin’s portables, which may be downloaded. I think the reason for this restriction is that Garmin is worried about the liability in case there is a mismatch between the database used to create a flight plan on the PC and the GNS 430.
The GNS 430’s have an “Aviation Output” RS-232 channel, which tranmits “PVT”, position, velocity, and time once a second. This goes to the Arnav display, but could also be tapped into by other things, perhaps through a cabin-accessible RS-232 connector. I plan to have this output channel wired to a DB-9 in the cabin so that I can have it drive Jeppesen IFR FliteStar running on a laptop. The value in doing this is that
a. It will keep tracks, like the handheld’s’, unlike the GNS 430’s.
b. Poor man’s EGPWS.
c. Makes flight replanning from present position easier.
The cost of adding this connector should be insignificant.
There are four bidirection RS-232 ports and two pairs of ARINC 429 inputs/outputs on each GNS 430.
Channel # 1’s input is connected to the transponder, so that the GNS 430 gets pressure altitude.
Channel #1’s output is the “aviation output”, which goes to the Arnav ICDS 2000.
Channel #2 is unused, but is reserved for Ryan TCAD (or presumably other TCAS/TCAD units as well).
Channel #3 is connected to the other GNS 430, for cross-fill.
Channel #4 is for the Stormscope, except that in the SR22 the Stormscope is only connected to the Arnav and the Sandel (two displays is enough for me).
The ARINC 429 output #1 goes to the autopilot and the Sandel’s GPS input.
The ARINC 429 output #2 goes to the Sandel’s VOR input.
The ARINC 429 input #1 comes from the Sandel’s selected course bearing output.
The ARINC 429 input #2 is unused.
I think the second GPS’s assignments are similar (transponder goes to both units), except that it is connected to the second CDI head instead of the Sandel and uses (I think) a combination of the ARCINC 429 I/O and the analog signals.
Cirrus has been experimenting with a unit by Honeywell that combines EGPWS (Enhanced Ground Proximity Warning System) and TCAS I. Flight tests show the EGPWS to be quite accurate. Honeywell is entering the GA market with a repackaged version of what they sell for the biz jet market. They claim that their EGPWS terrain database is better than anyone’s and it accurately displayed (on what display, I don’t know) the hills around Duluth.
Cirrus has been looking at the Shadin ADC-200 air/data/fuel computer as a possible factory option. The fuel flow sensor in the SR22 is already a Shadin unit, which makes the Shadin air/data/fuel unit easier to add. This will communicate with one of the GNS 430’s through one of the unused RS-232 ports.
The SR20 that J & R Avionics of Hayward CA added a Ryan TCAD to is still down (after 6-8 months), waiting for FAA STC or Form 337 approval (not sure which). The problem is that they mounted an externa antenna and needed Cirrus or a DER (Designated Engineering Representative) to sign off on the mechanical integrity of the a/c after this antenna was mounted. Cirrus didn’t help as their engineers were busy with Cirrus’s agenda and it took a long time for J & R to realize this, find a DER (in Oregon, btw), get him to do the work, etc. This is a cautionary tale. I certainly don’t want my a/c down for a long time, so I won’t be adding anything with an external antenna unless I’m sure that it will be approved. J & R is hoping that all the approvals will be done soon.
If the antenna problem can be solved, the Ryan unit with active interrogation, the 9900BX, still is not STC’s which means that you have to settle for the 9900B for now. Ryan is hoping for the STC “any month now”. The “B” can be upgraded to the “BX” for about $6,000, which is the difference in the price for the “B” and the “BX” models new. Just a circuit board swap to upgrade.
Due to the lack of the STC on the Ryan active unit, Cirrus is more actively looking at the BF Goodrich Skywatch (and the Honeywell unit).
The Trimble TRA3000 Radar Altimeter’s antenna must be mounted outside the skin, as even the non-lightning-protected skin of the SR22 reflects the 4 GHz signal too much. So the RA has the same problem as the Ryan TCAD – if you mount the antenna your a/c may be grounded for months.
The Honeywell unit, once blessed by Cirrus, sounds like a much better alternative than having a local shop add the Ryan TCAD and the Trimble RA. I plan to have the Arnav engine monitoring and the Shadin air/fuel/data computer added (no holes in the skin or the panel), along with Bose headset jacks and an RS-232 output from one of the GPS’s.
I pick up N567AB, SR22 #30, on 5/30. They had told me, just 2.5 weeks ago, that I could pick it up on 5/25, but I guess their production people are a little optimistic.
