Those of you trying to decide between buying an SR20 and a Diamond DA40 might be interested to read my little write-up at http://philip.greenspun.com/flying/plastic-airplaneshttp://philip.greenspun.com/flying/plastic-airplanes.
(I ended up buying the Diamond because I’m a very inexperienced pilot, my training was in a Diamond DA20, and I’m hooked on the superior visibility of Diamond aircraft. I’ve had the plane now for only about three calendar weeks and 30 flight hours but it seems to be very well made. My only real problem was a bad spark plug at 30 tach hours.)
Oh yes, I’ll be flying from Boston to Alaska and back June 3-October 15 so if you see 505WT or hear ATC trying to figure out what to call it (I usually say “Katana 505WT” to avoid a discussion and because nobody knows what a “Diamond Star” is), that will be me and the dog…
