Has anyone out there bought or used the SoftComm Centurian Headset. Making out my Christmas list.
I purchased two SoftComm C-100 ANR headsets earlier this year for use in a Tobago and returned both for a refund. Both headsets consistently malfunctioned when using the radio transmit switch on the aircraft control yoke. There was a loud stuttering noise that blocked the sidetone. ATC reported hearing a loud squeal when I used the headsets and transmitted using the yoke switch. I tested the Bose X ANR headset in the aircraft and it worked fine. I bought two Bose headsets and had panel connectors installed. I am delighted with the Bose.
