Leaving for Duluth in a few hours
Leaving for Duluth shortly. Paperwork and acceptance Tuesday. Factory training on Wed and Thur with Wings Aloft. Wings Aloft will accompany me back to the Bay Area Thur/Fri thru Sat/Sun depending on weather and other factors.
Insurance was difficult for a low time pilot like me, finally got covered for about $7K per year.
Will report on the way if I can, but most likely after my return.
Talk to you all soon,
Scott k.
$ 7000,- a year for Insurance? What is covered?
Thanks for an answer.
Something just doesn’t seem right with this, Scott. My quote, round number, from AOPA (500 hr VFR pilot) was around $2,200 annually with typical liability/event/per seat numbers.
Can someone who actually has actually taken delivery comment?
Scott k.
wHAT WAS YOUR POSITION NUMBER AND WHAT IS YOUR ASSIGNED SERIAL NUMBER?
I suspect that until there are more cirri “in the field”, the insurance quotes will vary quite a bit from company to company. I was given a quote from Avemco (whom I have pretty reasonably priced renters’ insurance from now) for about $5200 per year with $1M liability (something like $100k per seat) and $220k hull value. I’m instrument rated but only 250 hours.
I was told the reason it was so high was because it was composite – maybe they doesn’t insure many kitplanes and other composite aircraft???
I have since heard of people getting lower quotes, in the ballpark of what you mentioned ($2000-2500 annually).
I would think once the fleet has been in operation for a few years and they can gather some statistical claims numbers, the quotes will start converging a little closer - and hopefully on the low side!
I’ve gotten 3 quotes for $1.0MM/$100M. Two were in the $2,900- $3,100 and $5,000 through Scott “Sky” Smith.
I have about 1,000 hrs., IFR, Wings annual training, clean record and about 100 hrs/yr.
$7,000 sounds very expensive.
NOBODY PANIC! THE LAST TIME I TALKED WITH SCOTT HE HAD YET TO GET HIS PRIVTE RATING. SO THE QOUTE IS EITHER FOR NO RATING OR A RATING WITH NOT MANY HOURS. OUR INSURANCE IS WITH USAIG 100M,100K/220HULL/ ED HAS 600+/- INST TICKET
PARTNER DAVE HAS 160+/- NO INSTRUMENT TICKET AND THE PREM IS 3900.00/YEAR. THIS PREM IS USING THE LOWEST TIME PILOT ON THE POLICY.
I was just quoted $4000.00 a year for $230,000.00 hull value. The policy was for $100,000.00 with a $1 million limit. Thats for a 600 hour, instrument, commerical pilot.
Jim
