Hello Everyone. This is my first post.
Hello Wayne - welcome.
I have just taken delivery of a new SR20. I have also completed my “transition training” with UND. (They are Excellent!)
Congratulations! I (along with the members of COPA) wish you a long, happy, trouble-free and SAFE experience with your new baby.
I was hoping that other users could give me some tips regarding landing techniques and speeds. I am slowly but surely “unlearning” all of my 172 landing experience. My UND instructor really pushed a minimum touchdown speed of 80 knots.
Personally, I use 75 over the numbers, and WAY less than that at touchdown!. I subtract a knot for each hundred pounds below gross - so if it’s just me in the airplane, with half tanks, my airplane weighs about 2500 lbs, so I use 70 knots over the numbers (and 5 knots more on final). I was taught 80 over the numbers, but soon learned that the extra speed leads to excessive float; if you DO try to “put it down” at 80, you’ll bounce for sure! Of course, that applies even more once the instuctor gets out the airplane.
I have also noticed that I need to carry power until right before touchdown or the plane sinks with a pretty hefty VS.
Hmmm… can’t say I’ve noticed that. If you let your speed get too slow then that applies - otherwise, the airplane should not be doing anything unusual.
Finally, I have noticed that there really isn’t a flare as compared to a 172.
There really IS a flare, but it doesn’t LOOK like one. For me, what works is to fly at my “over the numbers” speed (see above) until I’m a couple of feet off the runway, and then increase the back pressure at just the right rate to prevent the plane from landing. The darn thing lands anyway, but it’s amazing how many of those are greasers. Actually, that technique has always served me well with any airplane, but of course it takes a little time to get the feel for that “just the right rate” thing. At this point, I’d have to say that the SR20 is the most consistent airplane I’ve ever flown for getting good landings.
I feel almost like I am starting all over again. I did 10 touch and go’s today and they were pretty good. However, 2 days ago, one of my landings bounced. I may have flared or I may have tried to level out a little too high.
My guess is that you had too much speed… see above.
(The sight picture is so different.)
That it is! I transitioned from a C182RG… with it’s high glareshield… I was amazed to actually SEE the runway during the flare in the SR20!
Anyway, I didn’t touch down hard at all but the plane bounced a little. Then, when the wheels touched down again, the plane bounced even higher. On the 3rd bounce I executed a balked landing and did a go-around. It spooked me a little because I didn’t land that hard at all. I am trying to determine what would cause this.
Speed…!
During training, my instructor had me do some no-flap landings in excess of 100 Knots. We touched down MUCH harder and the plane didn’t bounce on these landings.
IMHO, that’s still way too much speed (esp. if you’re talking about touching down at this speed!)
Can anyone give me some insight as to what causes this type of bounce (where each successive bounce gets bigger)? I am sure my mains touched down first on each bounce. My best guest is that I flared too-much and too-high and the plane dropped to the runway. Or, maybe I pulled back on the yoke after the mains touched down and the plane started to fly again.
I’ll leave this one to others who understand it better than I do… I have some theories, but I don’t know if they’re right. I’m pretty sure the very springy mains are part of it, though!
How do you “grease” landings in your Cirrus?
See above – just don’t let the sucker land!
Thanks in advance.
The best way to get great info is to join COPA. (Yes, this is an unabashed pitch). You should have gotten a “code number” from Cirrus, along with instructions on how to use it to get yourself a 60-day trial membership. I guarantee you that your Cirrus knowledge will start to increase, and keep doing so at an amazing rate, once you start accessing the Members Discussion forums. We’re simply the best aircraft owner group anywhere! (Don’t take my word for it – ask other members!) [;)]
