Couple of points - I don’t believe the logbook is required (they never asked to see mine) and the medical certificate must be in English. Regarding the BFR, I discussed this with an FAA guy at one time, and the conclusion was that 1) all US currency requirements must be met, including the BFR, and 2) a BFR or equivalent done OUTSIDE the US by a non-US instructor meets the BFR requirement - IOW if you’ve had a BFR done at home within the last 2 years, you’re ok, but if not you must do one in the USA with an FAA-certificated instructor. FAR 61.41 refers.
The temporary certificate issued will be replaced with a permanent one posted to your home address.
