In a way, we are all familiar with FADEC - all our car engines have it.
They work great when the sensors and wiring are perfect. But when a sensor fails, the engine stalls or goes into limp mode (extreme low power, enough to drive at 15 mph).
For example, my wifeās car (Infiniti G35) began stalling at every stop light (or stop sign). It would take several tries to get it running again. I took it for a test drive and weirdly ran perfectly for 10 minutes (never stalling at stop signs). Then exactly at 10 minutes, the car stalled at every single stop sign. Barely got it home.
Put a engine code reader on it. No codes whatsoever.
I knew it had to be a computer problem since the car ran perfectly for 10 minutes (spark plugs ok, air filter ok, fuel pump ok, battery ok). Car computers run āopen loopā for 10 minutes, then begin controlling the fuel flow and spark using sensors. This is called āclosed loopā.
So some sensor was giving the computer the wrong data and killing the engine. But which sensor was it???
I did hours of reading internet forums and watching dozens of youtube videos. Finally, one youtube described the problem I was having. Turns out it was the Mass Air Flow (MAF) sensor was dirty. Used a $5 can of MAF cleaner on the 2 sensors. BAAM, it worked.
So the car FADEC is simple a dumb computer controller with a look up table. The sensor outputs a voltage, then the computer uses a table and sets the fuel flow and spark to this. Absolutely no intelligence at all.
The reason the engine stalled was the MAF sensor unreported the air flow (due to the dirt). The computer set the gas flow way low to match this low air flow, thereby causing the stall.
Read the corvette forum or any car forum. These problems are epidemic on older cars as the sensors go bad. You will be shocked at how hard it is to troubleshoot these problems.
