I’m only getting 13.5 - 14.0 GPH fuel flow, full throttle on climb (SR20).
I think this might be unusual, and the cause for my 220+ degree oil temps.
Experience of others?
Thanks.
Andy
Thanks.
Andy
Andy,
I’m pretty sure mine is higher, but I don’t remember by how much. Will try to make a note of it today. Is your 13.5 - 14.0 GPH with the boost pump on?
Thanks.
Andy
My fuel flow is about 17 on the gage in the SR20.
Timm Preusser N747TG
Thanks.
Andy
Mike, boost doesn’t seem to make much of a difference.
According to my interpretation of the POH, which doesn’t seem to be specific, 14 seems the norm. Here’s my math:
(Page 5-24)
SL to 8,000 foot climb
11.3 minutes = .188 hours
2.6 gallons consumed
1/.188 X 2.6 = 13.8 GPH
Does this make sense to you?
Appreciate any input. Candidly, I hope my math is flawed. If it’s supposed to be higher, and I have it fixed, maybe I’ll have better performance in the heat. At this point, my oil temp goes to 220 and sometimes flirts with 230 on hot days. Top acceptable is 240, but this can’t be good for the engine. (Maybe it’s not a big deal.)
Andy
Andy,
- Mike.
Thanks.
Andy
Cirrus told me to make sure the main fuel pump is working at full pressure (always)! He said this can easily wear and requires periodic adjustment! If your speed has slowed somewhat and it isn’t ‘bugs’ it is probably the fuel…if it is the fuel…oil temp will soar. Maybe it’s me…but, i leave my ‘boost’ on during the steep climb and it seems to help a few degrees.
Don
(Page 5-24)
Andy
Andy,
- Mike.
Thanks.
Andy
Andy,
Here are the notes I made during climbout yesterday:
OAT = 18C
Climbing from 1,500’ to 2,500’
Forgot to note RPM and MP, but at max available power, mixture full rich:
Readings are Boost Pump OFF/ON:
ICDS Engine Monitor: 16.5/17.0 GPH
Analog gauge: 16.0/16.7 GPH
Hope this helps…
