Fuel flow issues
Have a 2000 sr20. In April fuel flow started decreasing Down to less than 14 gph on take off. Had the flow adjusted multiple times but still only reaching 16 gph on take off and fluctuating when airborne. Any ideas on how to track down the problem? Thanks
Do the old ones have an altitude-compensating boost pump?
If so, perhaps look there.
Also, you’ll have way more replies if you join COPA and post in the member section.
Our membership lapsed and I renewed today but I guess it is not instantaneous
Erik,
I show you as a member. Try Logging out of your browser and logging back in.
I assume take off with the aux pump set to boost? That’s the boost/off/prime switch version, right?
I would assume an issue with the aux pump is likely, at least more than with the main pump. If you switch that off in cruise, is the fuel flow stable?
There are two schools at least regarding the Cirrus aux pump. Some never turn if off, some turn it of in cruise, some in cruise but only if it’s not hot outside (I belong to the last camp). If you always run it, it’s going to reach end of life more quickly.
Maybe that’s something to try.
I’ve had this problem, with this symptom in my SR20G2. It needed to be refirbed to replace the aneroid.
What Bill said…the aneroid bellows for altitude compensation is failed/ing
What Tom said first and he’s not even a mechanic!
(I need some wins about now…)
You are a winner Tom!
Aneroid was a loser there…
Will this boost pump issue cause cylinder temps to be high?
Its not the electric boost pump issue above. Its the engine driven fuel pump.
Ok, the post above says fuel pressure is low and flucuating in flight.
Does this also cause any increase in cyl temps?
Probably
Good Afternoon, i am having this issue as well. was fuel flow erratic when you put it at a power setting?
we adjusted ours to 17.5 GPH at 100% on take off. took off and we were in traffic pattern and set it to 75% and FF was going crazy.
did you have the same?
