By default our forums are displayed in a “COPA Light” Theme. If this is your preference across all devices, No Changes are needed and you can close this message/Topic.
To make changes, There are Two(2) Methods of Switching to the “Dark Mode” Theme.
Indefinitely - Will stay the same based on the theme selected, regardless of OS/Device Settings
Automatically - The changes are based on the Users OS/Device settings.
Indefinitely...Steps to make changes
Step 1: Simply Select the Theme Preference (COPA Light, or COPA Dark)
Notes:
These updates are now apart of the CORE Forum software and should not require any updates in the future.
We apologize for the inconvieance.
Our Previous solution was a Customized Plug-in that was now out of date and was superseded by these changes.
Due to the nature of the Plug-in used, user preferences were not stored in our systems and were done so locally. This caused several issues that now should be resolved with this one time change.
Please note, that some devices have their own “Auto” switching behavior on them based on time of day and/or Ambient Light Sensors.
If you Select Enable Automatic Dark Mode Color Scheme the COPA website will switch based on the Device Settings and could be different at different times of the day.
This is Normal behavior.
Use Dark Mode on your iPhone, iPad, or iPod touch
Turn on Dark Mode for a great viewing experience in low-light environments.
How to turn on Dark Mode
Go to Settings, then tap Display & Brightness.
Select Dark to turn on Dark Mode.
You can also access Dark Mode from Control Center. Open Control Center, then tap the Dark Mode button to turn it on or off. Learn how to use Control Center on your iPhone or iPod touch, or on your iPad.
To turn Dark Mode on automatically at sunset or at a specific time, go to Settings > Display & Brightness and select Automatic. Then tap Options to set a schedule for Dark Mode.
