I have 1500hrs in a TB20GT. The in-flight pics posted above are my aircraft
http://www.peter2000.co.uk/aviation/tb20-experience/index.html
I am prob99 way too late in here to reply usefully to the OP (though I notice that he is in the Socata owners’ group right now looking for a TB20, while getting ridiculed there for asking here also!) but let me just say a few things:
The above performance comparisons of a TB20 with the SR20 or SR22 are nonsense. The MPG of all three is actually very similar if you are very careful to set up identical flight conditions i.e. same IAS (i.e. same thrust), same altitude, same OAT, same engine operating point (peak EGT i.e. stochiometric). I have measured all these in flight. I have also done the same with the Cessna 400 and surprisingly the DA42. At low level, say 3000ft, all of these do very close to 140kt IAS at 11.5 USG/hour, which in the TB20 is about 65% power. Evidently the Cirruses and the C400 have more slippery airframes than a TB20, but then throw away the advantage by having fixed gear and (in the case of the Cirruses) having to run the engine at a higher RPM which one can trivially verify in flight as being worth a few % (2500 versus 2300, say). The DA42 is perhaps the bigger surprise because it is a substantially bigger aircraft and is hauling along an extra engine, but the much higher compression ratio of a diesel does deliver a better SFC (the SFC increment is proportional to some root of the CR increment; I don’t recall the actual figure). The bottom line is that there is no free lunch in physics if you compare similar cockpit volumes and a 1950 Bonanza will deliver a very similar MPG.
The SR22 is of course faster than a TB20 - it has 300HP versus 250HP!
Socata parts are not generally more expensive than US aircraft parts. The engine related stuff (filters, etc) and avionics /electricals should never (!!!) be bought from the aircraft manufacturer (and every A&P with an IQ above 20 should know that) which basically leaves airframe parts. All airframe related parts are outrageously pricey and some selected examples (across all makes) are completely outrageous. Socata part costs have been creeping up lately but I still don’t think the costs are exceptional against US aircraft, in the context of normal servicing of an aircraft which has been properly looked after in terms of lubrication (yeah that is quite a condition to throw in…).
The comment about lead times going way out during a summer shutdown has never been my experience. The shutdown is only a few weeks. For US owners, there is parts stock at Socata Florida. For European owners, yeah, the distis do just buy parts back to back and add zero value, but that is how distribution works mostly everywhere…
The retractable gear is not a significant additional cost. I would estimate it at about $300/year and that is only if you use a really stupid company to do your Annuals, whose arm has to be twisted to use the right grease instead of squirting in some WD40. My expenditure since 2002 has been zero on parts, and the gear still looks like new in terms of wear. I used to pay extra to get it greased properly (the company refused to do it, saying it is not included in their fixed price Annual) but nowadays I do the Annual in a rented hangar, with an A&P/IA, and we just do it all correctly. It takes a few hours so it is just the labour cost of that. The TB20 has perhaps the most trouble-free and simple retractable gear system in the business which gives very little trouble - except on aircraft which has been utterly abused in terms of maintenance, but anybody buying an SR20/22 and not maintaining it is an idi0t anyway.
As regards which is nice to fly, that will always be subjective. I find the TB20 handling to be superb, and very precise. I did my FAA commercial/instrument in it and was amazed at how it deals with the chandelle. The Cirrus sidestick needs regular trimming to avoid one’s wrist getting tired and this tends to drive a lot more autopilot use. That’s not an uncommon comment for IFR tourers with a stick. But really all of these (TB20, SR20, SR22, DA42) handle very similarly in pitch and roll and all make good instrument platforms.
You can buy the most recent (2002 or 2003) TB20GT, in mint condition, with everything working, for about USD 220, and most go for less.
