I’ve been in touch with Jack Irwin who designed an electric tow called “Nose Wheel Dragger Dragger” that I have used on my Piper Archer. A gas version is also available at a reasonable price. He says that the castering nose wheel version can be developed for the Cirrus, but he needs the wheel pant clearance from the ground and OD of the nose wheel tire. Jack’s rig grips the tire, so part of the rig must fit under the wheel pant. The POH says the tire is 5x5, but he also needs the ground clearance. If someone with a plane can simply measure the ground clearance, we would be a long way toward getting a great tow. See the tow at http://www.dragger.com
Related topics
Topic | Replies | Views | Activity | |
Towing with Castering Nosewheel | 7 | 2558 | November 10, 2000 | |
SR22 Power tow and engine starting | 17 | 9822 | November 4, 2001 | |
Are you using Skyline Aviation Nosedragger | 9 | 2039 | November 20, 2002 | |
Nose Wheel Dimensions for Tug | 1 | 688 | March 4, 2024 | |
Aero-tow | 4 | 1535 | July 18, 2002 |
