Starlink Mini - Guide for Cirrus and other General Aviation users
As suggested I pulled the plane out and connected power and it worked just fine on the ground for a full 30 minutes. I’ll try it again next trip in the air and see. But no glitches for a half hour.
This cable works great and doesn’t require any adapters!
I’ve yet to be able to use it in the air.
Are we sure that Starlink still supports flight speeds on the Roam plan? Has anyone gotten in-flight internet on a Roam plan in, say, the last 2 weeks?
What it says on the Starlink site today (15 Feb 2026):
This is different from what the Starlink site said on 15 Jan 2026:
Paging @ErikGun because I read his article in the current COPA Pilot and started looking into this today…
Thinking I’m glad I never nixed the Local Priority. Honestly, not a surprise they’d change this again. Will be interesting to see if basic Roam is still working for anyone.
I flew yesterday. 200 mbps download speed at cruise.
I’ll test in the next half hour
This sounds like a cable problem. This cable from Amazon is recommended by True Blue to work with their 100W USB-C and is also confirmed to work with my Jackery 100W.
Working fine. Roam 100 plan… 175 knots true…about 145 Ground… stiff headwind.
That cable on amazon specifically say in the title:
vienon 5ft USB C to DC 5.5mm x 2.1mm Power Charging Cord for Laptop (5521), 20V USB Type C Male Input to DC 5.5 x 2.1mm Male Power Charging Cable up to 100W(Not Comaptible with Starlink)
Well I took the plane up today for a short ride and it is working at least at 140 knots and low altitude. No change in cable or Jackery. Hopefully it will keep working!
I can confirm this cable works with Jackery 100 and also True Blue 100W USB-C outlet as True Blue recommends these cables (funny it states otherwise in the amazon description). I do have the snow melt feature OFF. I just updated the SL with the battery and Vienon cable at home, but I’d probably recommend one of the other two just in case:
I went on a 4 hour trip twice in the last 2 days, to Dallas area and back to Tennessee. It worked great both ways. Only issue was on the return flight. I turned on the battery and had wifi on the ground. In the air it didn’t work and had to turn the battery off then back on and it worked fine. I don’t know if that’s the cable, the Jackery power unit, or it just gets jostled on taxi/takeoff and disconnects. For now I just need to order a new cord that’s much longer so I have easier access to the battery.
I did my second trip with Starlink this weekend. It dropped connection twice for a few minutes, and came back on its own. I also got an “antenna misalignment” error. Not sure how to address that given it is fixed on a Bradket.
Any help appreciated.
Was it doing a software update and reboot?
Had that last flight.
That vantage pic though :fire:
Misaligned error is common and doesn’t really matter as it’s always moving. Doesn’t seem to meaningfully affect speed.
Drop may have been software update… app will show status… I usually update it during flight when not needed as unlike my home which does it at 3am … it needs it. Takes a few minutes and will be offline
Use app to confirm snow melt off helps with power use and obstruction “confusion”
I flew today, and my Roam plan continued to work fine.
I think the two are unrelated Shyam. I get that misalignment error message from time to time. Can’t do anything to fix it in a moving platform but it is has never affected performance. It was complaining once and I ran a speed test, got over 200 meg, so obviously it was being fussy but not affected.
Others have said it might have been SW updates and I suppose it could be. SL does do them OTA, but I have never had it automatically reboot to install them. I have to manually ok it. Maybe something else is up. Might even be an antenna problem. Keep using it to collect data and experience.
Can anyone recommend a USB C to Starlink cord longer than 6 feet?
Works great/without issue to date
