I have been reluctant to submit this post but feel every owner of the new Cirrus SR-22 G Model should be very weary of accepting this aircraft UNTIL CIRRUS design admits they have lied to its customers, and redesign the parachute deployment system on this plane!
And I am reluctant to respond to such a post, but I am sure you know you are going to get cross examined six ways from tomorrow anyway, so here goes. Let’s start with the assumption you are referring to the SR20 G2 and the SR22 G2, there is no such thing as the SR-22G. Believe me, this makes a difference to those of us with steam guage ‘antiques’. Your header and first statement imply you don’t know much about Cirrus or their aircraft, so I see a credibility issue creeping in here. Also, what is the lie Cirrus has told the new owners?
I am an engineer…
Yep, saw that in your bio. An AVIONICS engineer. So it appears you are no more qualified to make judgements regarding structural engineering than well, uh…a cat.
… and in the process of researching this aircraft…
And I wonder for what purpose…
… have found out that CIRRUS HAS NEVER TESTED THE PARACHUTE SYSTEM in these aircraft! This is very important because Cirrus engineers have redesigned the brackets that hold the parachute system for the new SR-22 G.
I suppose you are under the impression that using CAPS (no pun intended, honest) would make everyone stand up and gasp in horror. REDESIGNING THE BRACKETS DOES NOT NECESSARILY MEAN THE PARACHUTE SYSTEM MUST BE TESTED. I assure you, there are safety components on your car that have been redesigned without being tested.
As an engineer I have concluded that the parachute if deployed WILL NOT WORK, as the harness kit is not strong enough to support the aircraft!
So you are, once again reminding us you are an engineer. That’s nice. I notice your area of specialty is once again, conspicuously absent. Also, you started out saying the BRACKETS were the big concern, but now you say (definitively, I might add) that the harness kit is not strong enough. This, you have concluded by relying on your knowledge of avionics, I suppose.
I am very unhappy with the response that I have from Cirrus in regards to this issue and have spoken to a customer service representative who informed me that she knew nothing about the re-design of the brackets to hold the parachute system in place, and went on to say that she “didnt think it was tested, as the parachute has worked fine in the past.” What kind of an answer is that?
And I am sure there are many of us in the Cirrus community that are very unhappy because you are unhappy[:(]. This “…response from Cirrus…” you are loosely quoting is ludicrous. Since you are an engineer, I would have expected better. You should have put your data together in a concise, to the point form and presented it to someone that could discuss it from a position of knowledge. I took a plant tour recently and spoke with couple of the guys on the floor about how they do certain things. However, I knew not to ask them about my warranty coverage or how to modify my current flight plan in the GNS430. In short, get your sh@t together and ask the right people.
So here is what I have concluded for all owners.
And I am sure I am speaking for everyone when I say “Thanks for thinking of us!”
- Cirrus redesigned the the upper part of the fuselage to hold the parachute system, but the re-design is not strong enough to hold the parachute if deployed.
Yadda yadda yadda
- Cirrus in their rush to produce this aircraft FAILED to test the parachute system to see if the re-design would hold the plane via the parachute system.
Are you thinking that putting ‘failed’ in CAPS (oops, did it again) would cause all readers to conclude there was a requirement to test it.
- Cirrus admits it did not test the system after the re-design because it worked in the past? Although not within the confines of the new engineering design.
Cirrus admits they did not test the system after the redesign?! Again, you are phrasing all of your statements in a manner that implies there is some sort of guilt here. Prove it!
Although I will not be flying in this weekend to Duluth, I would like those of you who are attending to ask questions and repost on here if you would be so kind.
That is the weakest attempt at false sincerity I have heard since the last car salesman I spoke to.
