I am working on trying to put together an accurate fltplan.com performance spread sheet. It doesn’t look like the poh has anything LOP above 55% power if I remember correctly. Where could I find a table for this, or better yet does anyone have a profile they could share with me to input for the SR-22’s I fly. They both have AC and are G1 and G2’s.
Disclaimer: every plane is different. In my NA G3 (w/ AC) I’ll start at 75% power, then mixture down to 25° LOP I’ll get ~66% power. 13.7gph and ~170IAS.
I wish ForeFlight would do the same.
Gordon, you don’t happen to have your TN still saved on this too?
Russ.
Yes, I do. I have two TN profiles stored. Use donor ID gordonf and aircraft N322PT-L for LOP climbs and N322PT-R for ROP climbs.
Thanks Gordon!!
I didn’t realize that heading west can pay to be up high too, the higher headwinds are counteracted by the higher TAS.
I just tried ABQ-VNY tonight and it recommended 16,000.
I wish ForeFlight would introduce something like this to help you pick an altitude, their system is very basic.
Yes, their altitude advisor is next to useless in a TN or a jet due to the extremely basic aircraft performance profiles.
I would say ‘worse than useless’. GIGO.
