I’m renting an SR22 based at SNA and do not have convenient access to the actual AFM. The aircraft is equipped with the semi-portable oxygen tank fitted between the two rear seats. Can anyone tell me the capacity of the bottle? I’m planning a trip and need to do the calculations on duration.
Thanks,
Lee
Lee,
I believe the oxygen you are using in the rental aircraft is the semi-portable 22 cubic foot cylinder from Precise Flight and provides supplemental oxygen for one to four occupants.
You will need to check what portable oxygen system you are using in the aircraft you rent to get the correct chart as this one may not reference the model you are using.
Thanks, Rick. I had all the other data except the cylinder size. I have the correct flowmeters, oxygen conserving canulas and the consumption chart. Thanks again for providing the key missing piece.
