Owning an SR20 or SR22 Monthly maintenance costs
Joe,
Of course - your topic is a very “loaded question”
sort of like asking “how long is a piece of string?”
There are basically xxxx categories of expenses.
Usage based - which will include expenses that are dependent on how much you actually fly… things in this category will be dependent upon and tracked based on flight time. Things such as:
  • oil change every 30 hours (the POH recommends 50 hours - best practices range from 25-35) - cost dependent on if you perform this yourself (legally as a private pilot) or pay a mechanic. This would include oil, filter, and oil analysis.
  • Engine reserves - some money set aside for engine overhaul - the suggested hours will vary - but the current motors are either 2000 or 2200 hours.
  • Fuel - depending upon which plane - you can reasonably estimate xx gal/hour - and use a local price - for estimation - I currently use $5.00 per gallon in my spreadsheet - will adjust with the price of fuel.
  • Cleaning and general maintenance - while typically not a big item - over time, there will be supplies, time, for wash/clean of the plane - the more you use it - the more this comes up… things like tires, brakes, ware items on the plane.
  • the Magnetos need what is called IRAN (Inspect and Repair as Necessary) every 500 hours (times two of course) -
  • Spark plugs - either 500 hours, or 1500 hours (for fine wire).
  • Alternators (times two) need to be IRAN every 500 hours
    Then there are CALENDAR based items:
  • Annual inspection
  • bi-annual pitot static inspection
  • parachute repack (10 years)
  • Co detector
  • Seat belt controller
  • Air bag controller
  • Hangar rent
  • Insurance fees
  • State/local taxes (in some areas)
  • Some folks include debt service (if financed) or cost of capital -
    Many of the items listed under calendar will be included in your annual - however, you can budget if you know that these various “life limited” items are coming due. You can build a spreadsheet - and approximate some of these items reasonably - but, there are of course MANY un-forseen expenses - so you always need a slush fund. The general rule - is NEVER allow this spreadsheet of expenses to be seen by a wife or significant other - Flying is NOT a inexpensive activity, and most folks are in agreement - difficult to ever “justify” the overall expenses.
This will get you started - you have been warned… I know of MANY folks that simply don’t want to know the bottom line because it is scary - but - we still love it… and do it…
Enjoy
-J-
