The Garmin 430 is almost certainly the most complex aspect of the SR2x aircraft. It has so many tricks packed in that I still find things I’d never found before, even having been working with them for six months or so.
I thought I’d share a couple of tips and tricks that I’ve come across that are handy for me, and encourage other folks to throw in their favorite “Stupid GNS430 Tricks.”
When on an active flight plan, if you highlight a waypoint and hit ->D ENT ENT, you will navigate directly to that waypoint. If, however, you hit ->D ->D ENT ENT, it will fly an intercept to the flight plan leg ending at that waypoint.
If you are flying an approach that uses the VLOC and you have the frequency of the navaid in the as the active NAV frequency, the unit will “crossfade” between GPS and VLOC guidance as you get in close to the FAF (so if you’re coupling the approach the transition will be smooth.)
If you have dual 430s, you can automatically crossfill the active flight plan or ->D destination. I think this comes enabled by default. I’ve found it useful to set up the two units so that #1 auto-fills to #2, but not in the other direction. This lets me play around with #2 (do what-ifs, or just mess around) without fear of messing up the primary (autopilot-coupled) navigation. To get the #2 back in sync, just hit ->D ENT ENT to recenter the #1 needle and the #2 will jump back in line.
I set the #2 430 to autozoom mode, but not the #1. Autozoom is nice for seeing runways and local detail as you get close, but is rather disconcerting when IFR and trying to anticipate waypoints (they keep jumping away but then coming in faster!)
Use NRST (airport) to go ->D to a nearby airport (such as your home airport when you’re doing local stuff) rather than dialling in the identifier.
Use NRST (VOR) to tune VORs, if you ever actually feel the need to do so (at least once every 30 days to stay legal for IFR.)
Use the Scheduler function to remind you to switch tanks. I’ve also set a scheduler to tell me to change the oil. It’d be nice if the MSG annunciator was echoed to the ARNAV, oh well.
Anybody else have their favorite tricks?
