Cirrus SR22 G3TN ARC parts issue
Hello fellow COPA members,
I am reaching out with an urgent request regarding spare parts for our Cirrus SR-22 G3 Turbo Normalized.
Our aircraft is currently grounded because the Airworthiness Review Certificate (ARC) cannot be renewed without replacement of specific V-band clamps. Unfortunately, Tornado Alley (TAT) is unable to supply these parts at the moment.
The required parts are:
  • 2 ea P/N: 11-1100023, V-Band clamp
  • 2 ea P/N: 9956T-0339, V-Band clamp
We would be extremely grateful if anyone in the community could assist us in sourcing these clamps – whether through available stock, alternative suppliers, or even possible leads to other operators who may have spares.
This issue currently grounds not only our aircraft but potentially others as well, so any help or advice from the COPA community is highly appreciated.
Hi @Henri_Kurz - you may have seen there are several threads on this issue that may provide more context to you.
https://forum.cirruspilots.org/t/anything-new-on-tat-v-band-clamps/282125/11
Hope you can find what you’re looking for.
Please note these topics are on the Memeber forums, and not accessible to guests.
Henri,
Welcome to COPA. Strongly suggest joining as a member to get access to the thread posted above as well as all of the other resources and knowledge COPA has to provide.
You only need two clamps: p/n 11-1100023. The other one you listed (IIRC) is the v-band clamp for the Bonanza.
Unfortunately these clamps are still harder to find than some rare earth metals. I haven’t seen any updates from TATI that they have them in stock. :confused:
Missed this was a Guest question. Thanks @hanstb!
@Henri_Kurz I’m late to the party, and hopefully you’ve already got some resolution on this. In the event you haven’t, or someone else is in the same situation - I spoke with Tornado Alley about two weeks ago. They are working on an alternate part and are awaiting approval, which they expect to have within the next 4-6 weeks.
Hello Derek,
That are great news. Unfortunately my plane is grounded since September due to the required parts (as written)
Hopefully that alternative parts are approved for the Cirrus SR22 GT3 TN
@Derek_Ingersoll could you please keep me updated?
For me lining in Germany, it is a little bit tricky to get new updates about this topic.
Thank you
Have there been any new developments on this? The new AeroForce™ V-Band Clamps have been PMA’d for just about all other similar turbo piston aircraft engines. AD 2023-09-09 does list the SR22 in Table 1; “Applicability Includes, But Is Not Limited to, the Following Airplanes, Helicopters, and Engines When Turbocharged.” I am reluctant to install a spot-welded v-band clamp that has had known failures when there appears to be a better alternative.
There are several active discussions on this topic on the member forums. If you join COPA, you will have access to them.
I thought I was a member. I am signed in and have an account and receive a monthly magazine. Help?
No, you are not currently a COPA member so all you see is the Guest Forum. At the top is a topic with instructions on joining. (There should also be a banner at the top with a link to join.) There are about 1.5 million posts on the member forums, so that’s an amazing resource, and posts you make on the Member forums will actually get read. It’s the best $95 you can spend in aviation!
Thanks. I see my father cancelled his subscription. I have Joined under my name.
