Brakes
Now that there has been a significant degree of time since the first SR20 delivery, do any of the folks with more than a few hundred hours in the plane have any comments about the durability of the brakes? Having a castering nosewheel means differential braking is needed to steer on the ground. Wondering if anyone has had any brake problems due to “there increased usage”?
Thanks, Brian
Thanks, Brian
I have 180hrs and have had an annual recently. No maintenance has been required on the brakes.
Robin Taylor
N144CD now has 200+ hours on the Hobbs. Brakes are doing a fine job of breaking and helping to point the nose where it should be on the ground. Must admit, have only found myself in 2 or 3 situations where hard braking was required (load and/or short strip)
Cheers from EHLE
HK
Thanks, Brian
We replaced our pads at the 300 hour service (airswitch). The aircraft has probably done about 350 hours hobbs and the original pads coped with a ferry flight to Australia (and all the extra weight of ferry fuel, etc) + the 5 syndicate members all becoming proficient in handling the aircraft. In all, I’d say they (the brakes) have done a great job.
Thanks, Brian
Robin Taylor
Thanks folks. The concensus seems to be that the brakes are holding up well.
Brian>N144CD now has 200+ hours on the Hobbs. Brakes are doing a fine job of breaking and helping to point the nose where it should be on the ground. Must admit, have only found myself in 2 or 3 situations where hard braking was required (load and/or short strip)
Cheers from EHLE
HK
Thanks, Brian
