I searched, but no info on the Forum. Does anyone know if the powered plugs in the SR22 will work with a Bose X headset? Any modification necessary?
Thanks for all the info.
Michael,
The aircraft powered plugs in SR2X will not work with the Bose. A set of two Bose power connectors will cost about $70. Of course this is of value only if you have/will purchase the Bose aircraft powered model. Cirrus will charge approx. 6 hours labor at $55/hr. to install the Bose connectors. Gary
