Attitude for Chandelles and Lazy Eights
Hi all, I am currently working with a student in a Cirrus SR22 for their commercial rating. This is my first time instructing in a Cirrus although I have a couple hundred of hours PIC in the SR22 airframe. My question is regarding the pitch attitude when entering these maneuvers. Right now, for Lazy 8s, I have the student entering the maneuver with about 12 degrees of nose-up pitch and Chandelles I have them entering at about 15-degrees nose up. The issue is that the airplane doesn’t get close enough to the stall speeds as laid out in the ACS and I don’t want to overdo it during an instruction flight.
Could any instructors here give me advice on which pitch attitude works best for them on these maneuvers? I looked in the iFOM and other publications but couldn’t find anything pertaining to attitude; only bank angles.
I just says “max pitch”…
Let’s wait for CSIPs et al to chime in.
I find that for Chandelles you have to target around 17.5 degrees or so nose up at the 90 degree mark to be ‘just above’ stall speed at the exit point. This will depend on loading/weight/winds though.
This is the reason why a pitch recommendation is not published. Moreover, if you want to be a purist, these maneuvers should be performed referencing outside points, not the PFD. The instruments are only used to teach the process. Otherwise commercial maneuvers should be performed looking out the window.
Agreed! Max pitch is purposefully vague.
For those coming from less performant airplanes it’s for sure more pitch up than expected!
Cirrus approach has a course on maneuvers which includes all the commercial maneuvers. I don’t recall seeing a pitch recommendation as noted.
Chandelles in a Meridian… A little sporty. :wink: Have to do them at reduced power to keep from going aerobatic.
