Any tips for starting. Planes been sitting for about a month or so. Located in the northeast. Should I rotate prop, run prime a little longer. Any recommendations.
Watch your fuel flow gauge while you are priming. Start counting to three once it reaches 10 gph. Then it will start like normal.
At the risk of being assumptive, you’ve preheated the engine, right?
Yes always.
