Is there a reliable test, mine seems fine when u wind it ut turns the prop but i has two instances of engaging the starter put the prop only moves a few inches, could not hear stater continuing to run, stater bench checks ok adapter does not slip when wound with a screwdriver
Any ideas what could have caused it no loose connections
I had a similar problem last annual. Could not duplicate the problem during repeated starts, however the battery did not pass a capacitance check. I replaced the battery and have had no problems in nine months. Battery was 4 years old.
Check the easy things first, cap check the battery. No reason to go hunting with expensive parts and troubleshooting before knocking the easy items off the list. @TonyWilliams and @rpmoll gave you the correct information.
Just had a friend swear to me his lawnmower starter was going out, wanted to check everything under the sun, same symptoms as you describe. I heard it start one time and immediately said time for a new battery, let’s test with a new one, sure enough that was it. He stated the battery was 1 yr old, until we looked at it, and the date code said 5yrs old
