NTSB Identification: SEA07LA002
14 CFR Part 91: General Aviation
Accident occurred Sunday, October 01, 2006 in Kalispell, MT
Aircraft: Cessna 340A, registration: N1920E
Injuries: 2 Uninjured.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed.
On October 1, 2006, approximately 1710 mountain daylight time, a Cessna 340A multiengine airplane, N1920E, sustained substantial damage following an emergency landing as a result of the airplane’s nose landing gear failing to extend prior to landing at the Glacier Park International Airport (GPI), Kalispell, Montana. T
Accident occurred Friday, October 06, 2006 in Stockbridge, GA
Aircraft: Cessna 177, registration: N2320Y
Injuries: 4 Fatal.
On October 6, 2006, at 0945 eastern daylight time, a Cessna 177, N2320Y, registered to and operated by a private owner, as a 14 CFR Part 91 personal flight, collided with a power line during climb out at Berry Hill Airport, Stockbridge, Georgia. The airplane was destroyed by post-impact fire. Visual meteorological conditions prevailed and no flight plan was filed. The private pilot, and three passengers were fatally injured. The flight was originating from the Berry Hill Airport, at the time of the accident.
A witness reported that the pilot conducted a preflight inspection of the airplane prior to his departure. The pilot told the witness that he was planning to fly over to St. Simons Island for a day trip, and returning that evening. The witness reported that the pilot checked his fuel tanks, and reported that he had “over 3/4 tanks full of fuel”. After the airplane was boarded the pilot conducted a run-up, and taxied to runway 29. During takeoff roll, the airplane did not get airborne until after approximately 2,000 feet down the runway. The airplane barely cleared a tree at the departure end of the runway, and continued to climb “slowly”. As the witness watch the airplane climb at an extreme nose high attitude, stalled, and clipped a tree. Seconds later two explosions were heard, and the witness drove to the accident scene.
Examination of the accident scene by NTSB showed that the airplane was located 509 feet from the departure end of runway 29, and came to rest inverted on the front lawn of a private residence.
Accident occurred Sunday, October 08, 2006 in St Charles, MO
Aircraft: Cessna 172N, registration: N4775D
The airplane was substantially damaged when it impacted the runway during landing. The pilot and passenger were not injured. The pilot reported that he was returning from a local flight when the accident occurred. He noted that the winds were calm.
Accident occurred Friday, October 13, 2006 in Tuntutuliak, AK
Aircraft: Cessna 207, registration: N7336U
Injuries: 1 Minor.
On October 13, 2006, about 1512 Alaska daylight time, a wheel-equipped Cessna 207 airplane, N7336U, sustained substantial damage when it collided with the edge of a river embankment during the landing approach at the Tuntutuliak Airport, Tuntutuliak, Alaska. The airplane was being operated as a visual flight rules (VFR) cross-country non-scheduled cargo flight under Title 14, CFR Part 135, when the accident occurred. The airplane was operated by Flight Alaska Inc., d.b.a. Yute Air Alaska, Anchorage, Alaska. The commercial certificated pilot, the sole occupant, received minor injuries. Instrument meteorological conditions prevailed in the area of the accident. VFR company flight following procedures were in effect. The flight originated at the Bethel Airport, Bethel, Alaska, about 1443.
During a telephone conversation with the National Transportation Safety Board (NTSB) investigator-in-charge (IIC), on October 16, the director of operations for the operator reported that he interviewed several witnesses to the accident, and learned that the pilot was attempting to land on runway 20 at Tuntutuliak. The gravel surface runway is 1,772 long and 28 feet wide. The approach end of the runway is located at the edge of a river. The director of operations said the weather conditions in the area had been good VFR, but as the pilot was attempting to land, rain and mist moved over the area, reducing the visibility to about 1/4 mile. The airplane collided with the river embankment as the pilot was on his fourth landing attempt. The airplane received structural damage to the landing gear, fuselage and wings, and came to rest about 40 degrees to the left of the runway. The director of operations indicated that within 30 minutes of the accident, the weather conditions were once again VFR
