Question…Does the SR22 come with the high end Skywatch or the low end 497 Skywatch unit?
Thanks.
Thanks.
I believe it is the 497 assuming that the 497 is the one designated Skywatch. The SR22 does not come with the Skywatch HP if that is the question.
I believe the SB covering that aftermarket installation of the Skywatch is posted on the Cirrus site. You could check that SB for details on which unit they are using.
