No flame, I too agree with the concern for pilot judgement in the original posting. So I wondered what the SR20 POH says about the conditions described. (I’m sharing this as part of a personal learning effort to get better at flight planning in challenging conditions, mostly because what I found surprised me! John Harper, I sympathize with your dilema in making this trip under such conditions.)
The final 2000 ft to 13500 was done at 100-200 ft/sec holding the plane between the stall horn at 75 KIAS and zero VSI at 80.
SR20 POH, page 5-22, Enroute Climb Gradient:
At 2900 lbs, 12,000 feet, 0C, climb at 88 kts is 139 ft/nm or 203 ft/min
At 12,000 feet with temps higher than 0C, the POH entries are gray.
The POH contains the recommendation above this table “For operation in air warmer than this table provides, use extreme caution.”
SR20 POH, page 5-23, Enroute Rate of Climb:
At 2900 lbs, 12,000 feet, 0C, cimb at 88 kts is 251 ft/min (curious why this differs from page 5-23; leaves me to use the more conservative number from above)
SR20 POH, page 5-24, Time, Fuel, Distance to Climb:
At 2900 lbs, 12,000 feet, -9C, speed in climb is 80 kts and rate of climb is 282 ft/min.
For temps above ISA, add 10% to computed values for each 10C above ISA. (Hmmm… if temp was +10C, then 20% addition would reduce speed and climb rate, eh?)
Two days in Vegas then off to GCN. Now we really were at gross, a bare 30 gals of fuel. 43 degrees and 2200 ft, so density altitude high but still well within the POH limits. … our best climb rate, … maybe 400-500 ft/sec (sic!)
SR20 POH, page 5-21, Takeoff Rate of Climb:
At 2900 lbs, 2000 ft, 40C, takeoff speed is 84 kts and rate of climb 737 ft/min.
The POH contains the recommendation above the table “For operation in air warmer than this table provides, use extreme caution.”
I’m worrying seriously about departure from GCN at 6600’ and Bryce at 7700’.
At 2900 lbs, 6000 ft, 20C, takeoff speed is 82 kts and rate of climb 582 ft/min
At 6000 ft with temps higher than 20C, the POH entries are gray.
So . . .
From my reading of the SR20 POH, all of the flight conditions stated in the original posting are NOT within the POH. In fact, the final climb to 13,000 feet is just about right but probably hot enough to be outside the POH, the Las Vegas temp is above 40C and outside the POH, and the speculation about Grand Canyon and Bryce are at elevations and temps outside the POH.
Now, since John compares the Cessna 182 in his posting, I went looking (but didn’t find) performance info for the 182. What I did find was an AOPA safety document Cessna 182 Skylane Safety Highlights. The document is quite complimentary about the 182. However, when discussing similar scenarios to John’s, it contains these paragraphs:
For example, a short-field takeoff in a C-182 at sea level, standard temperature (15 degrees C), and zero wind requires 1,518 feet to clear a 50-foot obstacle. If the field?s elevation is 3,750 feet with a temperature of 95 degrees, a common occurrence on a summer day, the density altitude equates to 7,000 feet. The 182?s takeoff distance will more than double to 3,185 feet. The maximum rate of climb at sea level is 865 fpm and decreases to 505 fpm at 7,000 feet. Add in terrain or obstacles and the possibility of downdrafts to negate the already anemic climb, and it becomes obvious why states with high real estate have much higher accident rates than the flatlands.
Remember that POH performance numbers are based on new aircraft under standard weather conditions with a test pilot. Most of us will not achieve the published numbers on a normal basis. ASF recommends adding 50 percent to all published takeoff and landing numbers, to allow a safety margin. Therefore, the takeoff distance from the same 7,000-foot density altitude airport becomes 4,778 feet.
Note the takeoff distance of 4,778 feet and the comment “ASF recommends adding 50 percent … to allow a safety margin”
That sealed the deal for me. I’m feeling a bit more focused now on my flight planning to Wyoming tomorrow.
Cheers
Rick
