Jim,
I disagree, but then that’s what keeps life interesting.
The deployment of the chute after a successful ditching may be worthwhile and offer some survival benefits. At worst, it would likely counteract the nose down submergence of the aircraft for a brief time, opposite reactions and all that. That might be a critical few seconds that can be gained.
WRT the effects of the chute in the water, it will act as a drogue, at worst, and sea anchor at best. This might help counter the nose down submergence of the aircraft for the simple reason that most aircraft would float if their center of balance wasn’t so far forward (some do anyway, but that is the exception). In a number of cases, aircraft have floated for hours when the occupant(s) have climbed onto the eppenage to counter this. Any force that helps counter the tail coming up would be an advantage. The chute acting as a drogue or sea anchor might well accomplish that.
Assuming it remains afloat, the advantage is that the survivors may have a dry place to await rescue, if they don’t already have a raft, and even if they have a raft, the considerable added viewability afforded by the aircraft and chute in the water will be a significant advantage when SAR comes looking.
WRT blowing a hole in the aircraft. This is on the top of the aircraft and is unlikely to have even the slightest adverse effect on the buoyancy unless seas were of such a nature that the aircraft would likely sink anyway.
WRT shooting the rocket off when there is fuel on the water, I’d suggest that common sense would suggest you might not what to do it then and any such leakage would be readily apparent under most conditions. Moreover, fuel leakage in GA ditching incidents while still afloat does not appear to be much of an issue. Most fuel leakage occurs, when it does, after sinking.
WRT, the chute in the water being a safety hazard, I think you are way off base. If the aircraft remains floating because of this effort, the survivors are going to be on or in the aircraft, or in a raft attached to the aircraft, in either case it’s not an issue. If the aircraft sinks, its not an issue, the chute goes with it. If the helo arrives for a pickup, with rare exception U.S. SOP is to deploy a swimmer away from the survivors who will swim to the survivors. He will pull the survivors one by one to the pick-up point and the helo will return for pick-up, again, away for the object in the water, be it a raft, boat, whatever. It is extremely rare for a helo to do a pick-up from a relatively small object in the water except when there is no alternative (very severe injury for example). In any case, a fully wetted and partially submerged chute isn’t a hazard for a helo anyway (BTDT on one offshore SAR exercise).
From my POV, the potential advantages for survivors in improving their situation far outweigh any possible disadvantages, which for the reasons stated, I believe to be minimal at worst.
Finally, while this entire suggestion is based on conjecture, it is also based on a good understanding of the potential risks and rewards and the dynamic effects involved based on my experience and such data as I could gather. Anyone who ditches a Cirrus at this point is already performing as a test pilot, though they at least have lots of successful conventional ditchings in single engine fixed-gear singles to guide them. Anyone ditching using CAPS is really a test pilot with little reliable data to rely upon since Cirrus have declined to provide any data on the forces that are likely to be encountered in a ditching.
Doug Ritter
It’s not often I run into someone more paranoid than myself since that’s pretty much the basis for my business and avocation, congratulations–I think.
