Just a word of warning that a NOTAM has been issued that will expand the P-40 TFR out to 10 nm for this weekend. This TFR is the one that currently exists around Camp David in Maryland. See the NOTAM below for details and see the attached graphic. Don’t forget to check with AFSS before each flight.
2/1724 - PART 1 OF 2 FLIGHT RESTRICTIONS HAGERSTOWN/THURMONT, MARYLAND. NOVEMBER 8-10, 2002 LOCAL. PURSUANT TO TITLE 14, SECTION 91.141 OF THE CODE OF FEDERAL REGULATIONS, AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED WITHIN 10 NMR BLW 18,000 FEET MSL OF 393853N/772800W OR THE FDK351014.8 FROM 0211082100 (1600 LOCAL 11/08/02) UNTIL 0211102100 (1600 LOCAL 11/10/02) SUBJECT TO THE FOLLOWING RESTRICTIONS UNLESS OTHERWISE AUTHORIZED BY ATC. A. ALL AIRCRAFT OPERATIONS WITHIN 5 NMR ARE PROHIBITED EXCEPT AS NOTED IN C BELOW. B. WITHIN THE AIRSPACE BETWEEN 5 NMR AND 10 NMR ALL AIRCRAFT SHALL: 1) BE ON ACTIVE IFR OR VFR FLIGHT PLAN WITH A DISCRETE CODE ASSIGNED BY ATC. 2) REMAIN IN TWO-WAY RADIO COMMUNICATIONS WITH ATC. 3) FLIGHTS WITHIN THIS AREA ARE FOR INGRESS AND EGRESS ONLY; FLIGHT TRAINING AND PRACTICE INSTRUMENT APPROACHES ARE NOT AUTHORIZED. END PART 1 OF 2 WIE UNTIL UFN
PART 2 OF 2 FLIGHT RESTRICTIONS HAGERSTOWN/THURMONT, MARYLAND. NOVEMBER 8-10, 2002 LOCAL. C. EXCEPTIONS: 1) MILITARY AIRCRAFT, LAW ENFORCEMENT, EMERGENCY MEDICAL ARE EXEMPT FROM THESE PROVISIONS UNDER THE FOLLOWING CONDITIONS: A) MUST BE IN TWO-WAY RADIO COMMUNICATIONS WITH ATC AND B) DISPLAY ASSIGNED BEACON CODE AT ALL TIMES WITH THE TFR. C) AVOID PROHIBITED AREA 40 UNLESS THEY RECEIVE U.S. SECRET SERVICE AUTHORIZATION BY CALLING 202-395-5918. NOTE: ALL U.S. SECRET SERVICE CLEARED AIRCRAFT OPERATORS BASED IN THE AREA SHOULD NOTIFY THE U.S. SECRET SERVICE PRIOR TO THEIR DEPARTURE. END PART 2 OF 2 WIE UNTIL UFN
