Hi We are new to COPA and are looking to replace our HID landing light with an LED one. We are currently looking at the Aeroled replacement and wondered if anyone has fitted the new six lens model that puts old 3300 Lumens and what their thoughts are ! Also would love to hear about other reasonably priced upgrades and outputs specs that other Cirrus owners have done. Many thanks and safe flying.
You will get much more of a response if you post in the Member forums rather than in this Guest forum, plus you’ll be able to do a search for “LED landing light” and see dozens if not hundreds of previous posts on the subject.
If you’re not a member, join! It’s the best $65 in aviation. If you have just joined, you may need to log out and log back in and/or clear your cache to access all the other forums and posts. In that case I can move your post to the Member side so you’ll get a good response.
Thanks Gordon that would be great if you could do that until I get a handle on this. Could you also correct a mistake I made. That landing light I mentioned is 3300 lumens. I was looking at the wrong spec. Thank you
