Works every time.Throttle full open and mixture.Fuel pump on.Wait for fuel pressure to swing.Bring throttle back down to a crack.hit starter you will see 3 blades then wammo. She’s alive.You can’t start with a vapor.So that is the way to turn it in to a liquid.After you do that you know you have raw fuel in the jugs.
Interesting; this is almost exactly the procedure I use in my plane which has a TCM IO-470-F. It works like a champ (not Aeronca Champ). I often wondered why the prescribed variance for the SR20’s engine compared to all other TCM fuel-injected engines.
