Marty,
At the risk of placing my foot back in my mouth…
I think the answer depends on the approach and depends on the reason for the vector.
If the vector is a “vector to final” then you are never authorized to fly the PT unless you get permission to do so from ATC.
The other situation is where ATC vectors you to join the approach at some intermediate position, perhaps even on the initial segment of the IAP inside the IAF. The clearance is to “intercept a portion of the published approach, cleared for the ILS 18”. As indicated in FAR 91.175(i) and AIM para 5-4-7©, you should continue to descend in accordance with the published IAP procedure. Then upon reaching the final approach course or fix, the pilot executes the procedure or continues on a radar approach (ASR or PAR).
The words “final approach course or fix” mean final approach course or FAF, not final approach course or “IAF”, which may just happen to be collocated with the FAF. The procedure to which the FAA refers in the rule clearly means the final approach procedure from the FAF (or final approach course on IAPs with no FAF).
For example, let’s assume that you are flying a VOR approach with no FAF, for which the IAF and the MAP is the VOR station. You are vectored onto a portion of the approach and cleared for the approach (letÂ’s assume that there is an arc with “NoPT” that leads you onto final). As per 91.175(i) you follow the procedural altitudes on the arc and intermediate segment. Once on final, you would descend in accordance with FAR 91.175(i), all the way to the MDA. At that point, you would definitely NOT cross the VOR, claiming that you are now at the IAF, climb up and fly the full PT. The final sentence in the AIM, para 5-4-7 confirms this:
“For this purpose, the Procedure Turn of a published IAP shall not be considered a segment of that IAP until the aircraft reaches the initial fix or navigation facility upon which the procedure turn is predicated.”
In other words, if you are given a vector to a portion of the approach that includes the IAF as a subsequent fix along the route, then you would execute the procedure turn – for example, if vectored onto a feeder route that goes to the IAF, and which is NOT marked as “NoPT”, then you would fly the procedure turn.
But just because you overfly the IAF, which happens to be the same fix as the FAF, does not mean that you climb up and fly the full PT. This would occur if you were vectored onto the intermediate segment. You are cleared to descend on the procedural IAP altitudes – the IAF is now irrelevant to your flight. You do not need it for anything because you are aligned on the approach and at the proper altitudes, and are probably below the procedure turn completion altitude. Looking at the procedure turn altitude and the altitude you’d be by following the IAP route, usually drives home the fact that a procedure turn is not authorized or required. You never want to climb to do a procedure turn.
Again, I would like to apologize for any confusion I might have caused.
