Is this a g1000 issue only or does it apply to avidyne as well? I have a G1 with ex5000 mfd only. I use Charts and data updates from JDM.
I think it is a file issue with Jeppesen but that is my take. LOTs of folks had this same problem with the charts file on the last update.
Any way you can direct me in regaining access to the checklist file? 2021 sr22t with fiki
Thanks
You should have the file in your PMs Lee.
Hello Hans,
Is there anyway that you could send me that link as well please? I have a SR22t G6 Perspective + with FIKI. I can’t find it anywhere on Garmin’s website. Thank you sir.
Terry
You should have the file in your PMs Terry.
Hi,
Does anyone know the location of (or are able to send) checklists for an SR20 G6?
Thanks, Matt
Matt-
PM me your serial number (or post it here), and I will send over the file.
Hi Hans,
Thanks that this: 2509
Hi Hans!
I need your help to. Thank you a ton in advance for all this! Same issue, had to delete everything and do a fresh install so I too need the SR22T checklists for my G5 Perspective + (with FiKi)
Zahir-
Just to bel clear, the SR22T G5 is Perspective (Not Perspective +), please confirm the file you need is for an SR22T G5 with FiKi, and I will PM it to you.
Hans, could you help me out! I deleted my checklist for my 2022 SR22 G6 NA FIKI no O2. serial # 8739. Email is joeadam6675@gmail.com. Thanks in advance!
Hello Hans can you please send me the checklist and any other supplemental files as well? 2022 SR22T G6 FIKI with O2. serial # 8863. Email is cm.gagnon@yahoo.com
Hello Cameron, welcome to COPA!
Most of the technical publications, and suplemental data can be retrieved (no login or fee required) directly from Cirrus by following the link below.
You should also have a set of SD cards stowed under the carpet lining in your baggage area. This case should include the Garmin unlock cards for your specific airframe as well as an additional card containing the entire Cirrus Technical library, including your checklist file.
Just feel around for it directly aft of the door, peel back the carpet a bit, and it is simply fastened to the fuselage skin with Velcro.
I sent you the MFD checklist file via PM.
Hans, I hate to be needy, but would you mind sending me the checklist file also? Had the same issue where I had to delete databases due to the corrupt NAV file.
SR22T with FIKI Garmin perspective+ 2021
If so, I really appreciate it.
PM sent.
Hans, thanks for the file.
I loaded it on a card, but I cannot get the file to show up when I try to update the checklist in the airplane. I tried a few times in both of the different slots the top and the bottom. Is there something that I’m missing? Do I have to put the serial number in or something?
Any help would be greatly appreciated.
