Sorry I wasnt clear - I meant it as a question I think ALT2 should power flaps but I heard that if ALT1 and BAT1 are down - then we lose flaps. Hence checking.
My SR20 G2 electrical system definitely does not power anything other than the Essential bus. It does explain why there might be some confusion. Here is its diagram:
I’d add that Cirrus has an amazing systems course that I revisit at least once a year on their learning portal. Absolutely worth the moolah. COPA membership is amazing, hope to see you on the “other side”!
I am only renting - so doing my due diligence before that. If I were an owner I would probably invest in a full membership. Otherwise I would have to be a member of all the types I rent - which would be a bunch
Thanks for all the answers ! You all were a big help !
