Electronic Checklists
Are the built-in electronic checklists in the Garmin glass panel modifiable?
Yes they are. https://www8.garmin.com/support/download_details.jsp?id=5075
Any chance the avidyne check lists can be changed?
id love to have my guy make some common sense changes
Cyril,
Sorry, Avidyne electronic checklists are not changeable. Perhaps a hacker could break into it. But short of that, no.
Others have already pointed to the editor from Garmin.
At least in my G3 TN I wouldn‘t use them without modification as the electronic checklists from Cirrus don‘t match the POH/TN STC. And yes, I had the latest version from the website.
Be aware that you are not allowed to remove items from the checklist which are listed in the POH.
Bernd
As others have posted, you can’t edit the checklists on the Avidyne system.
I would recommend the excellent Smart Check app for iPad which allows you to customise existing check lists, add new ones and attach useful documents for easy access.
Thank you all for the answers.
Bernd, you made me curious. Can you point me to something, a published limitation, a an FAA guidance or regulation, for example, which prohibits removing something from the checklist because it is in the POH?
Thank you for the link.
if you are into tablet-based electronic checklists, I would look at the multi-platform MiraCheck.
Personally, I’m mostly a paper guy when it comes to checklists, but it’s the best of the breed I’ve seen.
Big fan of smartCHECK. Hooked into my Bose A20 with Bluetooth it reads it to me as I check the item. Hard to beat and a COPA memeber made it
I have that app. I did not realize it was customizable. Im gonna work on that now.
Thanks
“Prohibited” might be too strong but if anything happens the attached document might be used against you:
“Pilots and operators, other than those operating an aircraft under 14 CFR Part 121 or 135 that choose to use COTS or personally developed checklists should meticulously compare them to the manufacturer’s checklist and placards contained in the POH/AFM to confirm they are consistent. “
I’ve reworked my checklists but I didn’t take out anything entirely with the exception of items inconsistent with the TN STC.
Bernd
SAFO17006.pdf (42.7 KB)
That makes sense.
And yes, if you miss something which you removed from a checklist and there is an incident because of it, you will have at least two problems.
Has anyone had success with the Garmin checklist editor? The program opens the chklist.ace file, but the editing options are greyed out. A google search reveals that Cirrus may have placed a lock on the file.
I’ve never had an issue and have edited mine many times but give this a try.
  1. Open the original .ace
  2. Use: File → Save As
  3. Save under a new filename
  4. Reopen the new file
Do not open the file directly on the SD card. Save it to your computer and work on it there and when done copy it back to the SD card. I hope this helps!
Nailed it! Perfect. Thank you.
Does updating the checklist change it for all pilot profiles, or can it be set to individual preferences?
I use electronic checklists on my EFB, “out of band” so to speak with the plane. It’s to bad if the reason you want a checklist is a broken MFD with the electronic checklists. I carry paper backup as well. I don’t want the checklist on the plane. That solves the personalisation issue as well, other pilots could have different ones in their different EFB. My wife uses the same electronic checklists though.
I fly different planes and helicopters, not just our Cirrus. I prefer some things to go with me, like checklists and ADSB traffic on the EFB moving map via a Skyecho 2.
You can try this too:
Although @dstclair (I think) said something about the encryption changing and this might not work anymore.
