I just bought a 99 sr20 and had a pre buy done. I had to fly it across the country and noticed when I landed, there was some oil leaking on the back of one of the blades of the props. I am going to have a mechanic look at it, but as this is my first airplane to own, am a little concerned with the costs. Does anyone have some ideas of what this typically is. Actually, instead of a pre-buy, I had them do an annual. Could something have been left off during this procedure? I am going to call the mechanic who did the annual on Monday, but it being halfway across the country, I don’t know how much good this will do me. If anyone could be of any help I would appreciate it. Thanks, James Tuggle
James,
Call me at 408 348 7058 anytime of night.
Alexander Wolf
James,
The constant speed prop twists in the prop hub to allow it to change pitch settings. There is a zerk fitting to grease the hub of the prop. At annual they put grease in that fitting. While there are other causes for oil on the prop, I would bet some of the grease worked its way out and in a few flights it will be gone.
Since your new to the plane, by all means have a mechanic verify it because there are other more problematic causes too. But clean it up and keep an eye on it. If its what I think it should reduce to nothing quickly.
Good luck and welcome to Cirrus ownership.
James,
Alexander Wolf
Alexander
Pardon me if it’s too personal, but ‘Call me at … anytime of night.’ has me wondering…
Are… you … Gulp…one… of …Gulp… these?
Vvvhhy yes, I am.
