I have an Air Lifeline flight for a two yr old with ALD and his Mom on May 27th; departing Boston and arriving in Baltimore a couple of hours later. Is there any local knowledge I should be aware of ? Particular FBO to park and fuel at ? We will be a quick turn and then head over to the Eastern shore ( ESN ) for a day of so and then head back home.
That would be me since I’m based out of BWI. FBO is Signature (only one). Tell them you are an AirLifeLine and they normally give 50 cents per gallon off for fuel (have AirlifeLine fax the waiver ahead of time). No other concerns. BWI is an easy airport in and out. I’ll send you a private message about some of the details.
Let me know if this will happen. Will try to make it over there and meet up with you on your quick turn (I’m 5 minutes away).
