Hello,
I am a guest on the COPA board, as I am currently finishing up the build of an RV-10. When designing the panel in my 10 years ago, I included an AVidyne EX5000 display from an unfortunate Cirrus SR-20. I proved to Avidyne and XM weather that I could make every thing work and play well in the sandbox with my other avionics including Garmin 530W. Keep in mind…my plane has NEVER FLOWN …but I have a problem.
The EX5000 was rebuilt and upgraded when I purchased it. Upgrade #1
During the building process…the screen developed a vertical line through the display, such that I purchased a 1 year warranty, and had the screen replaced. Upgrade and new screen # 2.
…and now…as my build is almost complete…the screen started to fade…and now has failed for the THIRD TIME! (Needing upgrade and screen #3).
I have called my local Cirrus dealer. They stated they won’t sell any plane with Avidyne Glass WITHOUT a warranty. Their experience has been that the screens fail every 2 years. They called Avidyne who would not repair the unit…as it was “out of warranty” even though the plane has never flown and only has about 2 hours of runtime. They did offer to reduce the repair from over $5000 to $1800. …and that’s the best they can do.
Based on the threads on this web board, it appears this is a long standing and well known issue. When even the dealers say it’s a problem…it’s a real problem. So I need your help. I would like to compile a list of failed screens. After all, this is a FAA CERTIFIED piece of equipment. We paid a small fortune for this equipment…and our lives…to some degree depend on it…and that’s why they get to charge $14,000 for this one device. I also paid for ChartMax, which I find to be completely underwhelming. That money will be wasted as well.
To say I am upset would be a large understatement. I am about to throw nearly $10,000 down a hole…as I will likely remove it from my panel all together. But before I do, I intend to get someones attention. I am weighing out my options. Perhaps my expectations were too high. Perhaps I am over reactiing. I welcome your thoughts, you comments, and your feedback. Yes, let the flame throwers begin.
Any information I could compile regarding the apparent large number of failures would be most appreciated.
Thanks for your help, your feedback, and allowing me to be a guest on your site!
Pete
– why the heck are you spending the money for a certified MFD in your RV-10? There are any number of other options with more features and much lower cost. One of the best things about EAB aircraft is the much more appealing set of avionics available out there, yet you chose to go with an Avidyne?
