Hi Gang,
Last question for at least 15 minutes :^o
What is the standard empty weight of your SR-20 (I assume that it differs slightly than the POH number).
Do the -20’s with the PFD weigh less than those with steam gauges?
Thanks again…
Rick.
Hi Gang,
Thanks again…
Rick.
Mine is 2166 with all of the options.
Paul N8153J (#1366)
Rick,
My 2003 SR20 has an empty weight of 2111 lbs. It has a 2 blade prop, cloth interior, EMAX, and gauges with no stormscope, 2nd 430, or other fancy stuff.
Emil
mine is 2136# Steam guages,& all the extras except leather
John
2002 SR20 #1251
Our 2002 SR20 (SN 1226) has an empty weight of 2133 lbs. It has a 2 blade prop, leather interior, EMAX, and gauges (‘C’ package)
serial # 1260. One of the last 4 or 5 vacuum pump specimens. C Model, everything except Skywatch–2148.
2004 Serial # 1393 Glass Panel with 2 blade, cloth, skywatch — 2,119 pounds
SR20 #1310 C model (or better SR20 - 220 series, like Boeing Airbus *) All electric 3 blade, everything but Skywatch. Soon to be fiited with ADF / DME / Garmin 330
SR20 100 series vacuum
200 series all electric
300 series PFD
400 series brain attachted to neuron-network ?
C model, 3 blade prop and all options except skywatch weighs in at 2146.
Raj
Looks like I may be the lightweight of the bunch
Empty weight w/ stormscope and 2 blade prop is 2085
915 useful load
