Post deleted by xyzebra
XYZ…
Please note the text on the main Forums page: “Contributors are asked to refrain from posting copyright material without permission…”. Did you get permission? If so, please post that, and if not, I respectfully request that you honor the spirit of our forum and remove this post. In this case, the link (click here) is publicly accessible, so there is no need to reprint the article anyway.
Thanks,
Mike.
when I posted my last link it simply printed the link in text…that is why I pasted it…
strange website that doesn’t automatically take links.
XYZ,
Thanks for removing that post. Now I understand the difficulty. You can easily make links clickable by inserting the following in your post:
text… http://www.abc.def.ghi Name Of Link text…
So, for example, your post could say something like this:
“Aero-news has published an excellent interview. Click http://www.aero-news.net/news/sport.cfm?ContentBlockID=5996HERE to read it.”
This mechanism is supported by the use of “Markup”, which is the default option when you post (see the pulldown menu that says, “Make post”). In addition, at the top of the reply form, the following message appears:
Fill out the form below to post a message on the forum. HTML is enabled. Markup is enabled, so you may use markup in your posts.
If you click on the link in that message, you will find a variety of other options you can use in compiling posts.
- Mike.
