Can you identify these aircraft?
Roger
I don’t know where to begin with the top picture, but the word “Avro” pops into my head for the bottom picture. Am I getting warmer? [:)]
Regarding the top picture; was it a B-29 decendant?
Andy,
It’s always good to start with “A” and work forward from there — but to get the name of the manufacturer, you’ll need to work your way onward through the alphabet. [;)]
Perhaps you were thinking of the Avro Manchester (see below), a twin-engine bomber that was less than successful in RAF service — due in large part to its unreliable Rolls-Rotce Vulture engines. (The same basic design evolved into the very successful Avro Lancaster with four Rolls-Royce Merlins.)
Roger
Andy,
No — although it’s the same vintage as the B-29, it’s from a different manufacturer.
FWIW, the B-29 ended up taking over the role for which this airplane was intended.
Roger
Roger,
Thanks for the pointer. [:)]
Yep. I had Manchester on the brain. Speaking of my brain, it is out of ideas so I am going to have to start hitting the airplane picture-books. [:)]
Andy,
Or perhaps you were thinking of Elsa Lanchester (from The Bride of Frankenstein) rather than the Avro Manchester…
Roger
Roger,
Well, I always have been attracted to older women, although not usually that much older. [:D]
Roger,
Andy,
Elsa was only 32 when she made The Bride of Frankenstein… which should be within your striking range!
Roger
Andy,
Definitely. If only I had been born in 1902! [:)]
Does the successful contestant win an hour of dual in an SR22?
The top picture is a Republic Rainbow. I don’t know the bottom one.
Republic Rainbow
No wonder it didn’t win the bomber competition. [;)]
You can get an hour’s ride in an SR20 — if you can make your way to Santa Barbara. [:)]
Andy’s guess was that the manufacturer’s name started with “A”. The next guess would therefore be…
Roger
Andy,
Actually, the Republic XF-12 (later XR-12) was designed as a dedicated reconnaissance aircraft for high-altitude, high-speed operations (the same requirement as led to the Hughes XF-11, in which Howard Hughes had the horrific crash depicted in the movie The Aviator). “Rainbow” is actually a pretty cool name for an airplane whose primary purpose was to gather light onto photographic film!
With the advent of reconnaissance versions of the B-29 and its higher-performance sequel, the B-50, the XR-12 contract was cancelled.
Roger
Andy,
Very interesting, Roger. Thanks for the lesson! Even head-to-head with the latest military aircraft, the Rainbow is one of the nicest looking designs I have ever seen. [:)]
Bristol Type 163 Buckingham?
Andy,
You got it — it is indeed the rather obscure Bristol Buckingham.
Roger
Woo Hoo! [:)]
