Does anyone know where I can buy or get a BAT Current Sensor No 14622-00A, Po829746? I have a MCU100 (Type 14600-012) in my SR22 G2 and it seems that the sensor has an error.
Thank you.
Did you ever figure this out (yes I know this thread is 5 yrs old!)
TCAir Parts has the following current sensor. I just bought one for my MCU120. You should ask them if it’s compatible with the MCU100..
It is. The PCB is the same. Just the enclosure is different. They are interchangeable.
$780 is just short of double what it was circa 2022. ![]()
Anyone have a breakdown of what the different pins do? Just found one if mine that a pin is broken off. Trying to see if that would cause problems, haha!
Thanks for your help. I think the Mill-Max sockets on the circuit board are the problem. When I clean the contact, it helps for a few hours, but then the problem returns. Sometimes it’s Alt 1, sometimes Alt 2. Maybe I need to replace the soldered sockets with new Mill-Max sockets???
Its probably not the cups but soldier joints and vibration. Which can wear out the cups…but is generally tougher on the torroids of rhe current sensors..
