Scott,
I think I understand what you are saying and where you are coming from, but I do have some comments and questions. However, I must say that I looked up your profile before I replied and I respect your experience and ratings. Also, I am a low time single engine land instrument pilot and am wanting to learn more about my passion, aviation. So, please don’t take my reply as argumentative, but education seeking.
My guess is that many pilots today are learning situational awareness from an electronic map instead of traditional VOR and other older forms of navigation. For instance, a good pilot will listen to a VOR’s morris code when they tune in to it and confirm that it is the right one, or it is active. I bet pilots who learn with moving maps will not see the need to verify a VOR signal, because when you say “direct to” a city and hit activate on a GPS, you’ll instantly know if you chose a city in Mexico, when you wanted a city in Minnesota.
Therefore, are you saying that pilots who have their current GPS card, may think they have everything there is to know about their destination at their fingertips and don’t need to check NOTAMs? I could see where this habbit may settle in, but we should always check for NOTAMs and AIRMETs before every flight. I admit that I don’t file a flight plan and check for airmets on a good VFR day for a flight of less than 45 minutes or so. But I should. I’m not sure that is because I have a moving map or because I am lazy. Maybe both. But on cross country flights, I do it all.
When you say “electronic” versions of the charts, are you saying jepp charts on a laptop or tablet, or are you also including GPS receivers and moving maps?
I think it’s a very powerful tool to be able to go on-line, file a flight plan electronically, and print out all NOTAMs from there. (instead of using a slow pencil) Even more so, have the computer translate the code into english. Is this available anywhere? I know that Avidyne is promoting this feature for their weather uplink, but can I get it on-line at DUATs or somewhere? Commercial pilots who look at them every day are used to the codes, but if it were in english instead of codes, I would be likely to take the time to review the NOTAMs. (I am also intimidated and embarrassed because I should be able to read them, but I forget how and don’t want to admit it)
What do you mean by “upon reaching the destination airport, ensuring that all applicable NOTAMs have been received.”? Why do we need to go check for NOTAMs after we land?
Ken
