I got a hot cylinder today. spiked immediately at full throttle on 1 to 2 seconds. aborted. Looking at data it was relatively at startup but in the green.
I am also seeing issues at cirrusreports.com cant login, started new account logged in once and not that password broken. Wont send recovery to my email for old or new account. Anyone else able to use cirrusreports.com
For engine I plan to swap sensors to see if its a bad sensor. Any thoughts?
I would swap the adjacent #4 CHT probe with #2. Just unscrew it from the cylinder using a 9/16" open end and swap them. Don’t undue the connector. There should be plenty of cable available if you remove a few zip ties.
See if the problem follows or stays on #2.
Using a borescope IMHO is standard procedure during oil changes… but then again I sell them so it’s like asking the Dentist if you have cavities.[:O]
